Portable Bevelers Offer a Smart Solution for Surface Preparation
These tools provide efficiency and cost savings
June 2025
By: LARRY PECHT
You’ve probably heard the saying, “The better the preparation, the better the finished product.” It rings true across countless scenarios, whether you’re gardening, painting, or working in manufacturing. And it’s especially relevant in welding. The more critical the weld, the more essential proper surface preparation becomes.
In many cases, rust and scale are removed through wire brushing, grinding, sandblasting, or several other methods. Then, a suitable angle is ground with a handheld angle grinder to maint..
Already a member? Log In
Search Articles
Publication Archive
View past issues of our magazines, including Welding Research Supplements in PDF format.
AWS News
