Aluminum Q&A
Aluminum Q&A
June 2024
By: TONY ANDERSON
Q: I have some questions relating to aluminum weldment performance:
1. I was informed that you should not weld on annealed aluminum base metals. Is this true and, if so, why?
2. Can I use thermal stress relief on aluminum welded components?
3. What are the typical tensile properties of aluminum welds at various temperatures?
A: I will answer your questions in order:
1. It is possible to produce sound welds on annealed non-heat-treatable aluminum alloys..
Already a member? Log In
Search Articles
Publication Archive
View past issues of our magazines, including Welding Research Supplements in PDF format.
AWS News
