Resistance Welding Machines Are Thirsty
How the right water chiller will improve your machine’s process and save money
July 2024
By: TOM SNOW
Long known as water hogs, resistance welding machines, including the subcategories of spot, projection, seam, upset, and flash welding machines, generate heat due to the high secondary welding amperages required for the process.
Therefore, an adequate flow of cooling water is one of the process’s most important variables, especially when a resistance welding machine is part of a high-speed production line. Depending on the application, conventional alternating current (AC) resistance welding machines require ..
Already a member? Log In
Search Articles
Publication Archive
View past issues of our magazines, including Welding Research Supplements in PDF format.
AWS News
