D15.1 Railroad Welding Endorsement
The AWS D15.1 Railroad Welding endorsement is a supplemental credential designed for Certified Welding Inspectors (CWIs) and Senior Certified Welding Inspectors (SCWIs).
By obtaining this endorsement, you demonstrate your expertise in welding railroad cars and locomotives, covering material and design, fabrication, inspection, and qualification. This credential validates your advanced knowledge and positions you as a critical resource for organizations in the railroad industry. Invest in your professional growth and enhance your welding credentials with the D15.1 endorsement
ENDORSEMENT EXAM PRICING
MEMBER
$430
NON-MEMBER
$695
REFERENCES
Most exam questions can be answered using the references listed below. Candidates can rely on their memory and experience, use the electronic copy provided on the testing computer, or bring their own bound printed copy of the documents
Comprehensive Support for Your Certification Journey
Whether you're encountering a technical glitch or seeking clarity on course content, our dedicated support team is here to ensure your certification experience is smooth and enriching.
Navigate to our Customer Service page and utilize the convenient dropdown menu to select the specific assistance you require, and a member of our team will help you.
Frequently Asked Questions
  • What is the D15.1 Endorsement?
    The D15.1 Endorsement is a specialized qualification for CWIs and SCWIs that focuses on the AWS D15.1code covering railroad welding. It demonstrates advanced knowledge and skills in specific subject areas such as material and design, fabrication, inspection, and qualification.
  • Who should pursue the D15.1 Endorsement?
    Certified Welding Inspectors (CWIs) and Senior Certified Welding Inspectors (SCWIs) looking to enhance their credentials and specialize further in the field of railroad welding should consider pursuing the D15.1Endorsement. Additionally, CWIs and SCWIs who need to recertify can do so by adding this endorsement to their certification.
  • What are the prerequisites for obtaining the D15.1 Endorsement?
    Candidates must hold a current CWI or SCWI certification. Familiarity with the AWS D15.1 Railroad Welding Code is also recommended before attempting the endorsement exam.
  • How is the D15.1 Endorsement exam structured?
    The open-book examination consists of 50 multiple-choice questions. The content areas covered include qualification, fabrication, inspection, reports and records, and materials and design. Successful candidates must correctly answer at least 72% of the questions to pass the examination.
  • How long is the D15.1 Endorsement valid, and how can it be renewed?
    Endorsements do not expire as long as your CWI and SCWI certification remains active and is renewed on schedule. Each time you renew your CWI and SCWI certification, any endorsements you have earned will also be extended.
