D1.2 Structural Aluminum Endorsement
The AWS D1.2 Structural Aluminum endorsement is a supplemental credential for Certified Welding Inspectors (CWIs) and Senior Certified Welding Inspectors (SCWIs).
By earning this endorsement, you demonstrate expertise in aluminum welding, covering material and design, fabrication, inspection, and qualification. This endorsement validates your specialized knowledge, positioning you as a valuable asset to organizations focused on aluminum structures. Elevate your professional credentials and open new career opportunities within the welding industry with the D1.2 endorsement.
ENDORSEMENT EXAM PRICING
MEMBER
$430
NON-MEMBER
$695
REFERENCES
Most exam questions can be answered using the references listed below. Candidates can rely on their memory and experience, use the electronic copy provided on the testing computer, or bring their own bound printed copy of the documents.
Comprehensive Support for Your Certification Journey
Whether you're encountering a technical glitch or seeking clarity on course content, our dedicated support team is here to ensure your learning certification is smooth and enriching.
Navigate to our Customer Service page and utilize the convenient dropdown menu to select the specific assistance you require, and a member of our team will help you.
Frequently Asked Questions
  • What is the D1.2 Endorsement?
    The AWS D1.2 Structural Welding Code - Aluminum Endorsement is a specialized qualification for CWIs and SCWIs that focus on the AWS D1.2 code covering structural aluminum welding. It demonstrates advanced knowledge and skills in material and design, fabrication, inspection, qualification, and reports and records.
  • Who should pursue the D1.2 Endorsement?
    Certified Welding Inspectors (CWIs) and Senior Certified Welding Inspectors (SCWIs) looking to enhance their credentials and specialize further in the field of structural aluminum welding should consider pursuing this endorsement. Additionally, CWIs who need to recertify can do so by adding this endorsement to their certification.
  • What are the prerequisites for obtaining the D1.2 Endorsement?
    Candidates must hold a current CWI or SCWI certification. There are no mandatory training requirements, but familiarity with the AWS D1.2 Structural Welding Code - Aluminum is recommended.
  • How is the D1.2 Endorsement exam structured?
    The open-book examination consists of 51 multiple-choice questions. The content areas covered include qualification, fabrication, inspection, reports and records, and materials and design.
  • How long is the D1.2 Endorsement valid, and how can it be renewed?
    Endorsements do not expire as long as your CWI and SCWI certifications remain active and are renewed on schedule. Each time you renew your CWI and SCWI certifications, any endorsements you have earned will also be extended.
