Jobs in Welding
Underwater Welder
An Underwater Welder uses many common arc welding processes to weld and cut in a wide range of aquatic environments.
They must use their welding know-how and intricate knowledge of diving procedures and protocol to effectively lay down strong welds, often in tight spaces and less-than-forgiving surroundings.
Hyperbaric chambers and cofferdams are used for dry welding, while wet welding is performed in open waters up to several hundred feet deep.
$62,000
Entry Level Salary
$68,000
National Median Pay
$100,000+
Real Go-Getters Make
Responsibilities
Responsibilities
  • Safe and efficient welding underwater, in a cofferdam, or other marine environment
  • Preform cutting, fitting, and rigging, to salvage sunken equipment
  • Calibrate all materials and equipment for welding and diving
  • Identify weld discontinuities and defects, and perform nondestructive testing.
  • Survey waters of various depths for obstacles and perform underwater photography and recording
Minimum Education
Minimum Training
Commercial diving certification
Recommended Education
Certificate in welding, metals fabrication, machining, etc.
Advanced Education
Associate degree in welding, metals fabrication, machining, etc.
Preferred Education
Underwater welding and commercial diving program
Recommended Training
Related work experience as welder or diver’s tender
Advanced Training
Apprenticeship program
Recommended Certification
AWS Certified Welder
Essential Skills
  • Highly motivated and self-directed
  • Prepared to adapt to a challenging work environment
  • Flexible and able to work in a team environment
  • Organized and detail oriented
  • Focused under pressure
  • Maintain physical strength and superior fitness
Work Environment
Underwater welders work in a variety of industries that are integrated within aquatic environments. Nearly all opportunities exist along the coastal regions and may require travel.
The heat map below showcases the total number of job postings for Underwater Welders in the last twelve months by state. As shown, the darker the color of the state, the higher the concentration of job postings. The heat map is intended to provide insight into areas where Underwater Welder careers are currently in demand.
Top Industries
  • Transportation
    Ship Building and Maintenance, Subsea Pipelines, Maritime Salvage and Recovery
  • Industrial
    Power Generation, Offshore Drilling, Water Treatment Facilities, Open Ocean Wind Turbines
  • Infrastructure
    Waterway Structures, Dams and Levees, Seawalls and Marine Docks
