Jobs in Welding
Robotic Welding Technician
Robotic Welding Technicians are responsible for the set-up, maintenance, and operation of robotic welding equipment.
Robotic welding technicians are critical to the fabrication of metallic parts or assemblies through welding by the means of a robotic machine.
Some operators are responsible for designing and programming the robot, maintaining and troubleshooting welding robots, and implementing robotic welding for manufacturing and production.
$54,000
Entry Level Salary
$60,000
National Median Pay
$95,000+
Real Go-Getters Make
Source: Lightcast 2025
Responsibilities
Responsibilities
  • Apply principles of basic welding fundamentals, symbols, and blueprints
  • Identify and perform correct robotic welding parameters, welding procedures, operations and programs
  • Create robotic welding programs, modify existing welding programs, and conduct welding cell cycle time calculations
  • Troubleshoot and perform preventative maintenance of robotic equipment and welding equipment
Minimum Education
Recommended Education
Certificate in welding, metals fabrication, machining, etc.
Advanced Education
Associates degree in welding, metals fabrication, machining, etc.
Recommended Training
Related naval or shipyard work experience
Advanced Training
Apprenticeship program
Recommended Certification
AWS Certified Welder
Essential Skills
  • Strong analytical thinking, problem solving, and computer skills
  • Knowledgeable of automation equipment, processes, and systems
  • Interpret blueprints and drawings
  • Adapt to technology changes quickly and seamlessly
  • Able to work independently and as part of a team
Work Environment
Many robotic welding technicians work in manufacturing or shop environments, however some field or travel opportunities are available.
The heat map below showcases the total number of job postings for Robotic Welding Technicians in the last twelve months by state. As shown, the darker the color of the state, the higher the concentration of job postings. The heat map is intended to provide insight into areas where Robotic Welding Technician careers are currently in demand.
Top Industries
  • Manufacturing
    Agricultural Equipment, Automotive Components, Electronic Devices, Aerospace and Aviation Components
  • Transportation
    Aviation, Automotive, Rail and Heavy Equipment
